SIMEX TF2000 DUAL DRUM PLANETARY DRIVE ROTARY EXCAVATOR GRINDER
Feb 17th, 2023 at 10:55   Construction / Logging   Langley   93 views Reference: 29
Price: $50,000 Negotiable
Description
PERFECT FOR 30 TON - 45 TON EXCAVATORS
BARELY USED EXCELLENT WORKING UNIT C/W HOSES AND PINS
CURRENTLY SET UP FOR OUR EC480DL VOLVO OR CAT 345-352 WITH PIN GRABBERS
WITH 100 MM MAIN FRONT PIN AND 90 MM REAR PIN BUT WILL FIT ANY 450-450 CLASS PIN GRABBER COUPLER
EASILY BUSHED FOR ANY 90 - 100 - 110 MM PINS
TAKE IT FOR $50,000.00
WILL SHIP IN NORTH AMERICA EXCEPT MEXICO - WE GET GREAT RATES AND FAST SERVICE
NOTE: THIS IS THE ONLY USED SIMEX TF2000 FOR SALE USED EXCEPT ONE IN QUEBEC THAT THEY WANT $100,000.00 FOR.
Recommended excavator weight (1) 28-45 ton 61700-99000 lbs Weight without bracket 2410 kg 5300 lbs Drum width (standard) 950 mm 38 inch
Simex TF cutter heads are ideal for trenching, profiling rock and cement walls, tunneling, quarrying, demolition, dredging, finishing operations, and underwater works.
They are highly effective where conventional excavation systems are too weak and percussion systems have little effect.
Their quiet operation allows them to be put to work near sensitive areas (residential zones, hospitals, schools, bridges, and infrastructure).
Especially recommended for finishing operations, where high precision, minimum disturbance, and the optimum aesthetic result are required.
Features
* Precise cut * Low vibrations * High performance * Low noise level * Deep and narrow trenches * Underwater works * Maintenance-free * Milled material reused on site
