EXTREME DUTY 350-550 CLASS EXCAVATOR 21 IN CONCRETE SLAB BUCKET
Feb 16th, 2023 at 13:52   Excavators   Langley   77 views Reference: 24
Price: $12,500 Negotiable
CAN TAKE SLABS UP TO 21 INCHES THINK EXTREME DUTY 350-550 CLASS EXCAVATOR 100 PINS WITH 16.5 INCHES BETWEEN THE EARS CAN BE WIDENED TO 17.5 INCHES
THIS BUCKET IS HEAVY ABOUT 5000 LBS YET DESIGNED TO BE AS LIGHT AS POSSIBLE TO ALLOW LARGE CONCRETE SLABS TO BE REMOVED AND LOADED OUT
TAKE THIS BUCKET FOR $12500.00 LESS THAN 1/3 OF THE COST TO BUILD AND 8 WEEKS LEAD TIME REQUIRED
HAVE THIS BUCKET WORKING TOMORROW
LOCATED LANGLEY BC - WILL TRUCK IN NORTH AMERICA - WE GET GREAT SERVICE AND RATES
Concrete Slab Buckets are the right tool for handling concrete blocks and broken slabs.
Slab buckets are built to withstand severe prying and ripping applications.
THIS BUCKET WAS CUSTOM BUILT FOR AIRPORT RUNWAY SLAB REMOVAL AND COST OVER $30,000.00 USD
CUSTOM BUILT OF HIGH-QUALITY STEEL C/W REPLACEABLE TEETH
A CONCRETE SLAB REMOVAL BUCKET FOR BRIDGE DECK AND CONCRETE PAVEMENT REMOVAL PROJECTS.
THIS CUSTOM BUCKET OFFERS LARGER OPENING FOR SLABS UP TO 21 INCHES THINK WITH A 54 INCH WIDE THROAT.
REMOVE CONCRETE SURFACES RAPIDLY
The process of using the slab removal bucket is quite simple. The existing concrete will need to be cut into smaller, more manageable pieces for concrete slab removal. The size of these pieces is limited only by the lifting ability of the machine as each bucket is built to withstand its unique weight class. At this point, the slab removal process quickly becomes a one-man job. Just slide the teeth under the pavement and tilt up. This action will cause the pavement to break off cleanly at the cut. The slab can then be lifted and placed directly onto the bed of a waiting truck or stacked out of the way. There is no debris cleanup and the subbase of the crab bucket doesn’t get damaged.
Solid Construction for Removal of:
Airport Runways Bridge Decking Sidewalks Roadways
THE KENCO VIDEO IS FOR DEMOSTRATION PURPOSES ONLY - THIS IS A CUSTOM BUILT EXTREME DITY BUCKET FOR 400-650 CLASS EXCAVATORS https://youtu.be/u2TgDFyjgI8
