33000 LB LOAD RATED LIFTING PLATE WITH WBM 600-850 CLASS Q/C LUGGING
Feb 16th, 2023 at 13:31   Excavators   Langley   74 views Reference: 18
Price: $3,000 Negotiable
LUGGING FOR A 2007 HITACHI ZX850LC-3 EXCAVATOR WILL FIT ANY 600-850 CLASS WBM LUGGED
COULD BE USED FOR HAMMER OR OTHER ATTACHMENTS TOP PLATE
THIS WAS CUSTOM BUILT IN 2011 BY 6S INDUSTRIES FROM NISKU ALBERTA FOR THE 850LC-3 EXCAVATOR C/W WELDCO BEALES QUICK CHANGE TO LIFT LARGE CEMENT MANHOLES AND DUCT WORK ENCLOSURES.
COULD BE EASILY MODIFIED FOR ANY 450 - 850 CLASS EXCAVATOR PIN ON STYLE MOUNT
BASICALLY AS NEW AND READY TO USE CURRENTLY BEING PROFESSIONALLY SANDBLASTED AND PAINTED - OR USE AS A TOP PLATE FOR LARGE HDRAULIC HAMMERS OR OTHER EQUIPMENT .
THIS WEIGHS 2700 LBS AND AS CAN BE SEEN IS LARGE NEW COST WAS OVER $10,000.00
I WAS TOLD AND BELEIVE THIS WILL ALSO WORK ON WBM QUICK CHANGES FOR 600 - 850 EXCAVATORS BUT CHECK FIRST.
THE PICTURES SHOW THE EXACT EXCAVATOR THIS UNIT WAS BUILT FOR AND FROM
BOTTOM PLATE 48 INCHES LONG X 36 INCHES WIDE X 1 1/2 IN STEEL PLATE DISTANCE BETWEEN EARS IS 27 1/4 INCH EARS ARE 60 INCHES OVERALL X 2 INCH STEEL PLATE TRUNNIONS ARE 10 INCH DIAMETER EARS ARE 19 INHES HIGH SLOPING TO 17 INCHES HIGH GIVING AN OVERALL HEIGHT OF 21 INCHES
UNIT WASPROFESSIONALLY BLASTED - PRIMERED - AND HIGH QUALITY CAT YELLOW PAINT SPRAYED
TAKE IT FOR $3000.00
NEXT DAY PICKUP IN BC OR CALGARY OR EDMONTON AT OVERLAND WEST DEPOTS
I GET GREAT RATES
604-476-7777
